Sea doo just sputters
Janine
I have a 97 GSI, it starts right up, but idles a little rough, the information system keeps blinking LOW FUEL. The sea doo bogs right down when I give it gas. I have replaced the plugs, no luck. Where should I start trouble shooting. Is the fuel pump in the tank?
The water/fuel filter under the handlebars, then if you see grey lines change them into auto parts store lines, most skis use about 20-25 feet, clean the steel gas can trash from the fuel inlet filters on the carbs and inspect the fuel control, anywhere air could leak in will cause lean burnout, the fuel pump is inside the mag carb - this is why leaks are critical to be certain fuel flows good at all times.
I'll give it a try
Voodoo, I am going to trailer the ski tomorrow. When I get it home I will start replacing lines and cleaning filters.
Thanks
