Sea-Doo Challenger 180 Float Switch Fuze
Dunhams5624
I installed a new blige pump and float switch, but the float switch does not turn on the pump automatically. I can manually turn on the pump with the battery full on and Manuel switch pressed. Is there a separate fuse for the float switch and blige pump? Where can I find the float switch fuze if so? Any suggestions?
I guess I could replace the switch or test the power if there is no fuze to replace. Thanks!
There is a fuse for each of the circuits of the bilge pump. The fuse for the 12 battery is right at the battery in my Speedster. The fuse for the switch is up in the fuse box under the console.
Curious, did you buy the pump and float switch as a combo?
My advice is to replace the pump with a pump with an integrated sensor to ovoid a float switch.
I will look for the fuze. I bought them separate because it was a replacement for what what there. Figured it made the wiring simpler. I will let you know if the fuze did it. Thanks
