hi have just bought a Sea Doo Sportster 1800 has worked well in the beginning but now one of the engines is just bad on the 1.5 engine. have cleaned carb has been out of the running with it but still it goes bad would be grateful for some help
/ Cona
Mark the oil tank and use premix gas until you know the oil is working and drinking, when you mix oils sometimes gel grows and jamms the system then you can flush with kerosene and use something you can buy easily to refill - cut the label off your first empty bottle and keep in the glove box.
hello voodoo
he may be well with the oil smokes a lot but when it reaches just under 4000rpm and has forward and does poorly on wet one spark plugg
in the beginning was good about an hour ago stopped by one motrorn did so every time I was out
then started to always go bad on one engine
