jondrew
I've seen the thread in here about prepping your motor/pump with WD-40, CRC, Silicone Spray. I had my Utopia 185 for 5 years and never got it in salt water. I just bought an 07 GTI SE and would like to get it out into the intercoastal and or the Gulf here in FL.
When you say "wash the motor off with fresh water and then spray it with WD-40 or CRC", do you mean spray that stuff on when the motor is wet? What other parts of the engine compartment should be sprayed? I guess linkages and cables sprayed with silicone? What about treating the battery connections with lithium grease?
Is there anything you dont want to spray?
