RXT-X shakes a little on idle only 5 hours
sigelitest
Have a new RXT-X and took it out for the first time. it only has about 5 hours on it. when I was bringing it back in it was shaking a little on idle. is that normal?
I was driving it fast, i coudnt help myself.
do u think I should have been easier on it for breakin?:facepalm:
Could have sucked up something and threw the prop out of balance. I had a vibration at around 6000 rpm and had the prop reworked and rebalanced. The vibration went away after that. There are a lot of prop shops in my area. It cost around $150 to have it checked and repaired. Although you would think that if it was a prop issue it would get worse as engine speed increased. If you can get the dealer to check as a warranty covered issued that would probably be your best bet.
What part of Alabama are you from? I'm from Athens, AL. Athens is right off of I-65 about 15-20 miles south of TN if you're not familiar with it.
