RXT X Fault code P2428
jetgrl
Hi Guys,
Just wondering if anyone has any info on the P2428 Code? I have replaced the sensor and the code has come up again.
I`m going to take a look at the 3 holes in the j pipe are not blocked, is there anything else I should look for?
Cheers
P2428
High exhaust temperaturedetected
Exhaust overheat, damaged sensor or damaged circuit wires. Check cooling system for blockage. Check if the exhaust injection valve is properly calibrated.
Hope that helps.
Check if it's actually over heating! It's cooled by water therefore should be hot only to the touch.. If it isn't over heating, shoot the wiring etc. If it is hot then the sensor is correct and you need to shoot for cooling flow..
