my wear ring was due for change, so i did. now, 3 wear rings later and only a few secs with each wear ring, i need another. wen i put each wear ring in and then the prop, it all has minimum clearance and turns inside the pump unit well without touching at all. once i bolt the pump unit up and then start the ski ( '04 RXP ) i notice small shavings of wear ring being spat out. i test ride the ski and it cavitates majorly but has great top speed. i go back, pull out the pump unit and those shavings seem so minute. 3 times i have repeated this process. any1 with any clues
