running 4-tec out of water
scgck
Is it normal to get water running out of the jet pump as well as the exhaust when running the 4-tec on a hose on the trailer? If so I guess the some of the water would have to run backwards through the exhaust manifold and out the inlet at the jet pump? Thanks
Water
This is totally normal. When your using the boat, water comes from inside the jet pump, thru the exhaust system and then out the flush fitting. Water is running in reverse when you are flushing......going in the flush fitting and coming out the center of the pump. You should ALWAYS have water coming out the center of the pump when flushing.....if not then you have a clog in a hose, the pump or a hose has come disconnected inside.
DAWG
Thanks Dennis, We are going to the lake tomorrow and just wanted to make sure this thing is working right before we get there.
Chris
