Esmalls
Picked up a Rule 25s automatic bilge pump for my 2013 GTI 155.
Pump is floatless automatic that AutoCycles on every 2.5 minutes to test for water in hull so cannot hook directly to battery.
I just need to know what wire / connector I should hook it into to get a hot switched power lead.
I plan on using the Weatherpack connectors like sea doo uses for all of their connections.
So if you know what connector specifically I would want to run this to that would be PERFECT
Any info on what connections / wire to hook into for power is GREATLY appreciated.
Like to keep my wiring tidy and factory looking. also like the ability to plug / unplug it as necessary.
Similar to this sea doo kit
Thanks in advance
Thanks in advance
