Took the carbs off one of my GTX's to clean. putting back on and noticed that the cable linkage going to the oil pump does not spring back. if I pull the cable by hand to move the lever it does not return on its own. I was wondering if this is normal or is there a broken/missing spring on that lever? everything moves freely. This is the motor that is oily inside the crankcase if that makes a difference. Thanks!
