It appears that something fell down into my carbs when I was rebuilding them and jammed the rotary valve. It's not turning. The leading edge of the valve is damaged and the cover has some pretty deep grooves in it. The block has some very minor circular scratches--barely catch your fingernail on it.
So I've got several issues.
I'm hearing that there is a plastic internal gear, and that it's possible to remove the external gear and get to the plastic gear and replace it without pulling the engine. Any comment or instructions?
I understand I'll need to replace the cover and the vane, but are the minor scratches in the block a deal killer? I guess I can have the refaced if I remove the engine, but I'm trying to make this as simple as possible.
If I get to that point, what's it take to re-time the valve? I see some threads about that.
I got this ski for free and have spend a ton of time and a little money replacing all the fuel lines, rebuilding the carbs, replacing all filters, etc. It was running but not well, worse after I did the carbs. Found the valve damage. Good compression both cylinders, ski is in excellent condition otherwise.
Any input on this project would be appreciated.
