It could be a rod bearing, but before we jump to that conclusion lets do a couple of checks.
A cylinder that is misfiring badly could sound and act like a rod problem, so start by pulling the plugs and having a look at them. If they look fairly old replace them and check the plug wires while you're at it. Before you put the new plugs in do a compression test on all the cylinders. If one is more than 15 psi below the others you may have a problem. Before panicking though be sure to spray some of your two-stroke oil in the cylinder and recheck it. If the plug was shot the compression may read falsely low due to being washed down.
Start here and get back to me.
Aaron:cheers:
