turbosl2
I have a 2003 Sea Doo Challenger 1800 that i am going through and getting ready for spring. How do i set the ride plate to factory specs, and what are they and measured from?
Also,
I have a cable operated steering assist, of which the cable tension is so lose it does not pull on the carb linkage. I adjusted it so it moves the linkage about 1/4"but i have no idea if this is to much. Is there a procedure for this setup? I even had to adjust the angle because it would open the linkage/carb plate one way 1/2" and the other stay closed.
Seems that i have to go through EVERYTHING on this boat and get it back to spec. I rather do what i can on the trailer in the garage and fine tune on the water, rather than do everything on the water.
Thanks
Also,
Thanks
