UPDATE on this, I haven't been on here in awhile, the problem I was having with the ski that was driving me crazy has been solved. It wasnt the thrust washer in the pump, it was actually a combination of 3 things, 1, even though I bought an OEM ring from the dealer, brought the whole pump down to the dealer, mechanic took it apart, verified the washer was in right, bearings were good, impeller shaft was straight, he cleaned the threads since they had some corrosion, put the impeller back on, was STILL rubbing, he said there was something on the pump housing under the ring, but I know I cleaned it real good, so I think I got an slightly defective ring, anyways, 2nd problem,the ski has a weak starter, apparently not helping the problem with the ring being so tight, and lastly, and most embarrasing, come to find out after messing with it for hours trying to get it to start, apprarently my "finger trigger happy" sprayinbg of fogging oil last winter was the main problem, I obviously over did it by ALOT, the thing was full of so much fogging oil that when was trying to start it, it was acting like a cylinder that was full of gas, long story short finally got most of the fogging oil out of the engine, and got it to turn over enough with the pump loosened up a bit and spraying the wear ring with WD-40, finally got it to start and run and tightened the pump up, lets just say I didnt have a mosquito problem for a hour or so because of so much smoke LOL.
