uraceulose
Replaced both oil pumps due to the fact that the previous owner was running pre mix and I’d prefer to use the oil injection system.
I have everything all back together and took it down to back into the water last night on trailer, trying to get carbs straightened out so it will run and wanted to get oil pumping through the small tygon lines so I can get back to injection.
Before firing it up and after replacing the pumps..I reached down to the bleeder screws and loosened until oil was gushing out of them. There still seems to be a bubble in the big lines, when I went down to the launch and ran it at idle...it got a few little pulses of oil that pumped up into the small 3/32 tygon lines that I could see but seemed to stop pumping and the lines definitely aren’t full of oil like I expected them to be after holding wide open for 10-20 seconds or so.
Any ideas? Should I just hold it wide open longer on the oil pump arms?
I’m still going to keep this first tank with pre mix in it to be safe. I do feel resistance on the arm when I hold it open and did wind it up to where the cable has tension if that makes sense to be sure that the pumps were clocked correctly and have the marks lined up at idle.
Thanks for any suggestions
Donnie
Donnie
