mejim707
I have a 96 Seadoo Challenger. I've had an issue in the past where after running the boat on the water for a while, if I shut it off on the water it wouldn't start up if I let it sit for a while. Someone suggested that the gas tank vent may be the issue not allowing the fume build up to escape and instead creating positive pressure in the tank forcing extra fuel into the cylinders and flooding the engine. I'm not sure how much truth there is to this but just to be on the safe side I'm thinking about replacing the vent. It looks easy enough. The only issue is that the part is unavailable / discontinued. However I did fine this part on amazon. Do you think this will work? It looks more durable and higher quality.
https://www.amazon.com/Sea-Dog-352110-1-Tank-Vent/dp/B000ZFUYOM
Thanks
Thanks
