rebuild questions
killer454
Ok I got my engine tore down 2005 rxt looks like they replaced the blown supercharger and did not clean out the engine so it spun a rod bearing.
My question is my cylinders have very light vertical scratches in them nothing that catches your fingernail but they are there.
Can anybody give me a part number on the nickasil cylinder hone they bought I can't find one
Thank you 4" bore
Ok I called the company that makes the flex-hones and they told me to use part number-gbd400240ao
This is a alluminum oxide material made only for nikasil cylinder did you guys know to use this material when honeing 4-tec
Ok I ordered the following
All new bearings
New crankshaft
All new solid valves
Gasket kit
Flywheel bolts
New hone
New rings
I would say my oil pumps are bad to but have not looked at them yet.
My valves where showing rust around the whole bottom of the valves.
