Hi Lou
thanks for the reply you mean buying the top end?well im taking the top end a part and will see what im going encounter.i took the top covers and i did see one piston bad
I guess so i have got there yet.
i wondering if you can tell me the best way to get there?the motor still inside do i have to pull out or can i do it with inside?
do i have to remove the carb?
thanks for ur reply Lou
What Lou is telling u is if your crank is locked up like you said ur gunna need a full rebiuld or get a new motor from sbt the crank is in the bottom end sbo best bet is to pull spark plugs and see if you can turn motor over by hand.
Also yes you will want to remove Carbs and do a fresh rebiuld w a fresh motor. Why chance messing up a new motor. Good luck and let us know if its locked up.
