1990 SP.
It's been sitting for a couple of years.
Long story short......I wasn't getting fuel to the carb, so I started back tracking towards the tank. Filter was clean. I pulled the pick up assembly off, to check and make sure the screens at the bottom of the tubes were ok, and low and behold...both tubes were gone!
Ethanol got 'em I reckon. Both only had about an inch of hose on the nipples, and the rest has crumbled down into the tank. I got some more hose, (And installed a clear inline fuel filter so I can see if it picks up any of the crumbled hose), but here's my question.
I'm guessing that the pick up tube going down into the tank, is longer on the reserve side, and shorter on the primary side, so it will run out on the primary side first. I don't have any old tubes to look at, and I didn't see in the manual any lengths stated. It shows one longer than the other, but not by how much.
So....how much shorter should the primary side be, than the reserve side?
Question number 2........am I asking for trouble if I don't get some new pick up screens on the bottom of the pick up tubes, or will the fact that I installed an extra filter be good enough. Logic tells me I'll be ok without them, unless it trys to suck up a piece of that old hose that is large enough to block the intake of the 5/16" hose.
'Preciate the help.
'Preciate the help.
