bigler
I found a guy that is going to do some work on my GSX and he said i have to buy the parts that I need. I have the old grey fuel lines so i am having him replace those and the carbs most likely clogged pretty bad. Do I need to buy a rebuild kit or can you just clean out the filters? My ski doesnt go over 4,000 RPM and can only get to like 15 MPH with full throttle. My ski also cavitates really bad when I have a passenger and also accelerates slow from stand still. So im pretty sure I need a new wear ring.
So I am wondering what I am going to have to buy for parts.
- I know I need new fuel lines. 25 feet of autozone fuel line. 1/4 inch right?
- Do I need a carb rebuild kit or can the mechanic just clean out the filters and stuff?
- New wear ring? they cost $65 so i dont want to buy one and find out the old one just needs to be adjusted or something.
- I also know that there is a tool that he will need to remove the impeller to get at the wear ring. I assume you need a special removal tool for seadoos. there isnt some different tool that will work that any mechanic will have?
Thanks in advance for any help
