Question about Seadoo 1998 bombardie xp limited transmission shaft
erica0718
Hi, I want to consult a question with yall; When I remove the transmission shaft and try to put it back on again, it always has an inch extra left out, which can't fit in. I hope yall can assist me with it!
Hhmm,,,happened to me once,,,there is the midshaft connector,,,i guess you would call it,,,and it come out the coupler,,and it is not visible,,,so,,,1st make sure the drive coupler is in at the pto daisy coupler of the motor,,,then you can
proceed backwards to the mid coupler,,and then the rear coupler,,,then the pump will go in..
