icemanOpie
This Is probably a no brainer but I am new to 2-cycle engines using a rotary valve. I have become aware through many hours spent working on a 1990 xp,  given to me via frustration of a friend, with the 587 yellow motor that the rotary valve gear is stripped on one side. It was given to me with the oil tank removed. I actually rode it for about 30 min. then abruptly died.  Obviously if the rotary valve is not turning, It will not run. My question given all this info is.. Will it run with premix without the rotary valve plate as many other 2 cyl. 2 strokes that do not have reed valves or rotary valves?  Or is the rotary valve critical to deliver the fuel to the right cylinder at the right time to this particular engine? Yellow 1990 587 btw. I also understand the other possibilities of twisted crank, wasted bearings, etc...junk motor...just wondering if the engine will run w/o the rotv.
