Bobbuff
Good Afternoon Everyone, I broke down and decided to take my Sportster 1800 to the shop to see why my starboard motor is purging. The mechanic pulled the plugs and told me that I have one plug that appears to be getting fuel and was a little wet and the other was completely dry and looked brand new. He stated that what was happening was that I had a whole in the diaphragm on my carb and that was the reason why it was purging. When I asked why I only had one plug getting wet he stated the same problem. He did all of this without even starting it or putting it under load. My question is does this sound right to you guys??? I am getting ready to pull the carb and rebuild it and just want to make sure that this is the problem. I asked if he did a compression test and he said it came back with 120 psi on both cylinders. I thought I read somewhere that it was suppose to be 140 but not sure he told me this was fine.
Also, I successfully just pulled the jet pumps off my boat for the first time and found it to be rather easy. I will be posting picks of the wear rings and impellers in just a few minutes. The spacing I think is a little to much but since this is the first time I have ever looked inside one of these I just want to make sure I am right in thinking that. I am having major cavitation problems and I know that the wear rings are the first starting point.
