I have been trouble shooting a ski that will start on the trailer, but not in the water. Reading on the forums (can't find this procedure in the service manual), I have seen a few people testing the crank seals by blocking off the exhaust and intake and then pressure testing the crank via the pulse line to 10 psi to see if it will hold pressure. On my first test I could hear a bubbling noise that was loudest coming out of the jet pump as the pressure dropped, ( I assume the sound is resonating through the pump shft). Test two I got to about 8 psi before the pressure gauge on the oil tank blew off. I blocked off the oil line w/ my finger and tried again, it held 10 psi for about 2 seconds when a loud gurggle and bubbles ran up the oil supply line into the oil tank, I had the oil cap off to prevent the press gauge from popping off again. Anyone know what this means? First test the press bled off fairly slow as I heard a guggling noise coming from the jet pump area? And is it normal for air bubbles to come up through the oil supply lines?
