Pulling 240 efi
Deadlygunz
Hello
I’m trying to pull my motor. 240efi on my 2000 challenger
But it seems to be stuck
I lifted it with a forklift but no movement at all
Ik got all the 11 bolt out
Anyone an idea or trick to get it out
Cheers willie
Hello
Cheers willie
Looking at the parts list-
there are 11 M10 NUTS under the casting, including directly behind the expansion chamber.
Suggestion-
Re-install 4 of the nuts loosely. If you lift the engine and it springs up, it can come down uncontrolled. With the nuts loose, it can only rise enough to break the gasket seal.
Oke i have the 11 nuts loos
So far so good
But when i lift it with a forklift
I lift the compleet boat but it wont come loos
I tried hammering it but not a mm its comming
Sorry for the bad englisch
Suggestion-
Hello
Yes i did get i free
Pulling it straight up is the way
And i hammerd chisels betweet de gap en cut the gasket between with a knife
Hope you get it out
