Good day everyone, I’m looking for some advice on how to pressurize the fuel system on a 95 XP, i took a look at the manual and it says to have the fuel selector in the off position, to block the vent line coming out under the rub rail I believe and pressurize to 5 pounds through the inlet line that has the pressure relief valve, then to change selector to on and reserve and repeat procedure. Am I missing anything? I haven’t really had a good look at it, the machine apparently bogs at high rpm but has good compression so I was going to check the fuel system for leaks as I can smell fuel, take the carbs apart and check for genuine Mikuni parts, check the pop off and check for leaks, see how it runs then and procédé from there. Thank you in advance for any and all replies
		 For the fuel system check.....What I do is clamp the fuel lines a few inches away from the fuel baffle.  I clamp both, ON and RES and put the pump on the inlet line to the carbs.  That way I get the whole system.  Main things I concern myself with is the water separator and the fuel valve.  I pull a vacuum first.  I do this because that is what the fuel pump is doing.  If I can't pull and hold 5 or so pounds vacuum there is a problem.
 THANK YOU.
 THANK YOU.
