seadoobie
Ok so I've been having a problem with my one way check valve leaking oil into my engine compartment. I thought the valve may be faulty & replaced it with new valves twice now and it still continues to leak.
I found that when the oil cap is tight it does this, oil creeps up the vent tube and drips out. I have to keep the cap kinda loose and then things are fine, no leaks from the valve. It seems like pressure is building up in the oil tank or something to push the oil out like that.
I'm not sure if these oil caps vent pressure or not, since valve is supposed to let air in to stop vaccum lock, but I dont like loosing oil and also having to clean it up all the time.
Anyone else have this dumb problem? Thx in advance!
