scrisp Active Member May 4, 2015 #26 Racerxxx, does that seal need replaced everytime the pump comes off, or only if it is damaged?
racerxxx Moderator Moderator May 4, 2015 #27 Some may say every few times and they're shot. I'll say use your best judgement. Unless it's torn, damaged or has no "spring" left in the neoprene than I would replace it. That does not mean it will last for ever either.
racerxxx Moderator Moderator May 4, 2015 #29 It starts at a 1/4" thick, after you install it.....tight enough to keep water and air out
