Done searches and haven't found anything yet, but if the poppet valve is stuck open can it prevent the telltale from discharging water even at high speed. Obviously I have no flow at all out of my telltale on the water. Just got the boat, but I did pull the outlet hose from the expansin chamber and had good flow, and no overheating alarm. I know I need to check the telltale for restriction. Also under the poppet housing is a little wet whichmakes me think the diaphram is bad. also My boat is in the water, If i tried to flush it would the extra water flood the exhaust into the engine? Thanks
