crazeejames
Just need some clarification on popoff testing.........If I pressure up with the needle "dry" I just get a hiss and slow release of pressure...........is this normal? If I spray the needle down with wd-40 or carb cleaner, It "pops", would this indicate a poor needle/seat, or does it have to be sprayed down to test?
What would symptons of improper 'Pop' be? I'm having issues of starts fine, idles fine, but as soon as throttle goes above 3000rpm, missfires, occasional backfire..............been thru electrical, carbs clean.......just pulled them again to check this Pop..........
