Poor performing '08 GTX
Skeedattle
:banghead:
I have '08 GTX that sat for a while before we attempted to use it. We added fuel and it started right away and seemed to run fine. It went about 300 yrds and bogged down then quit running.
We brought it ashore and drained all the fuel thinking it was poor fuel, charged the battery overnight an dstarted it the next day. Again it ran for a while then bogged down and quit. I checked the fuel supply and it seemed good. I cheched the plugs and they are firing. Seems to me to be a fuel supply problem but with fuel injection im not real sure which way to head with this one
After sitting for a while or sometimes we would relieve the pressure on the fuel system and then it would run for what seemd like 2 or 3 minutes then it qould quit again.
We went thru this scenario several times and finally pulled it out of the water completely.
Anyone have any suggestions before i take it to the dealer
There is a filter on the bottom of the fuel pump. You'll have to pull the pump out of the tank in order to check it.
will the pump slip out of the tank after i remove the stainless steel clip or do i need to remove all of the small bolts around the pump housing
Do not remove the clip. Remove the nuts around the housing. Not sure about your ski but removing the pump on older models was easier if you removed the glove box.
I removed the glove box already, guess i gotta remove the rest of it now.
