SeadooChallenger1800
Yesterday we went to the lake. After 1 our of boating. I heard an scratching sound. The bilge was full of water and it wat a little bit brown. Set the bilgepump on. It went out. Saw than that a water line that sits on the exhaust (small one was of). I repaired it and everything was fine. Until one hour later an oil warning light came on. After 5 minutes i was at the boat ramp. I trailert it went home. I did an flush with 3 new litres of oil. Set it in the garage and all oil was out 2 hours later! I looked in the engine compartment and saw the oil line the one on the top (reverse line) It looked like it was a little bit burned against the exhaust. There is a very small hole in the line i think 2 mm. Is this the problem? Checked every other line. All are good. Is it possible to lose so much oil in so short time? Hope you can help me! Sorry for bad english.
