snoope
Hi. I bought a used 2010 Seadoo 130. The seller did a water test and it seemed to run fine. Today i put it in the water. Immediately it had a P0562 error code (which seems to be a voltage/battery issue). The battery light was flashing. It was also beeping. I had it out for around 15 mins and it was sluggish. It then became hard to keep it balanced. I got it back to shore and opened it up. The hull was full of water. Around 60% full. The plugs were in tight. There are a lot of repair and patch jobs to the hull. I have rented these many times, but never owned. What are your thoughts on the problem?
