PLEASE help! I want to ride!
2001 GTX 951 DI.
One fuel injector sprays the other injector does not. When you switch the fuel injector wires the problem moves so it in not the injector itself.
Where should I go from here?
Details:
2001 GTX 951 DI with 170 hours.
I bought it last year with a burned up engine expecting a to do a top end.
I did fire it up and it sounded horrible but did seem to run.
I pulled it and went with a full premium rebuild on my own block from the Seadoo Engine Shop in Horsham.
Two weeks ago I finally got it back and I paid a Seadoo mechanic to install it because I was too busy at work and I just want to ride.
Friday the shop called and said it's ready to go!
I picked it up and immediately noticed some loose fasteners. One intake manifold bolt was loose and the bracket that holds the exhaust pipe to the block on the starboard side under fuel injection rail was loose.
I complained and they said the mechanic has gone home for the day.
I took it home swearing under my breath. I tightened the fasteners down (with some difficulty because he had miss-aligned the exhaust bracket. I had to remove the fuel rail to align and install the bolts for the exhaust bracket under the fuel rail. I have worked on fuel injection system on cars and diesel trucks and felt confident removing and re-installing the fuel rail.
I tried to fire it but it would not run. It tried to run with some coughing and spitting but it will not go. It is very rough and would not idle or rev.
Yesterday I took it back to the mechanic and they did some testing.
The owner and two mechanics all swear they heard it running good at the shop prior to me picking it up.
I was there today and observed the following.
With the fuel rail pulled up and out of the air injectors so that we can see. Fuel sprays from the rear injector when the engine is cranked.
No fuel sprays from the front injector when the engine is cranked.
When you swap the wires fuel sprays from the front injector and not from the rear injector.
Both fuel injector wire plugs are clean and tight with no corrosion.
I have checked every plug on the engine and computer and all are clean and tight.
Where should I go from here???
PLEASE help..... I want to ride!
2001 GTX 951 DI.
Details:
