michaelfw3924
I have done everything I can think of. Rebuilt rave valves. Checked solenoid. Replaced check valve. Checked water valve. Checked fuel filters inside carb and out. Rave lines have no leaks. It won't go over 6100 rpm and I pulled the plugs while driving and were gray and super dry. My fuel selector is not clogged and I don't have gray fuel lines. Cheap compression tester with like 14 inch hose showed 130 on both cylinders. Plugs should be wet right? I should get higher that 6100 rpm.
