Ok so i bought a 03 gtx 4 tec first time on tje lake and it started bogging down. In the no wake noticed the back was sitting low so thought i might have forgot to put the plugs in so i get to shore and pop the seat and its full of water about half the engine covered. Drained it and put it back in to see if i could find the leak immediately found water rushing in from the bellow and the carbon seal so i thought that was my problem. Order new kit started takin the c clip off and noticed alot of play in the drive shaft. Took pump off and bearings fell out everywhere so ordered a new pump put carbon ring and fixed the leak. Took it to the lake hit the start button and it barely wanted to turn over. Tried maybe 3 or 4 times then relay started clicking. Anothe try it clicked again then nothing at all not even a beep when i put the key on the post so bought new battery put it in and relay still just clicks.
I pulled the plugs still just clicks. Found the wire to the starter was loose so tightened it up still only click from relay. Its the updated black box relay and im not sure how to jump it to see if it will start. I tried jumper cable from battery + to the post on the starter still only one click and cable got really hot after only 2 pushes of the start button.
Anyone have any idea what it could be?
