Hoping someone can chime in. i posted the question in a different thread and had lots of good info from timmyboy but I have nothing on what the condition/color of the pistons are telling me here. the pictures are from my 787 with 3 hours on the new top end and 23 on the new bottom end. The three hours also had new mikuni 40mm sbni carbs with mains at 147.5 mag 1 turn and 150 pto with 2 turns along with prok arrestors. There was also a carbon fiber rotary valve that was not factory degree but a bump up to make for low end. Everything else was stock. First two hours were great but very hard starting after warmed up. the last little run it started sputtering and running funny (just did not feel right) so i limped back to trailer and took home. Ran compression and i have 5 psi dif in them. being paranoid i decided to tear down and inspect.
One other thing. The pto jug was full of water so the drain at the bottom must not be working. I replaced the hose with clear hose 23 hours ago when i did the entire motor late last year. The hose is clear of any debree and the mag side was drained fine. When i removed the head i noticed water in the pto cyl on the piston. I cleaned asap and used a suction gun in the bottom end looking for water but found nada there. WD everything and wiped cyl walls clean.
If you have some info please chime in. Thanks
