keegster17
Does anyone no a good service and parts dealer in Toronto, Ontario? I am on the west side closer to Mississauga. Also what is the average cost to have a 2004 Seadoo GTX winterized?
I found that manual not very clear. I had the oil done in May, should I change it out, for the winter? Thanks duane72 for your tips.
I will do a search thanks. i probably change the oil as mentioned. Are the oil filters easy to fine or am I required to go to a marine store? I will also read about fogging the cylinders, as I am not sure what that means. Yes I am in canada, so it gets cold here, I am hoping I can get the oil and filter from a store like a Canadian tire or local auto store.
Got to www.sea-doo.com and click on the "locate dealer" tab at the top right of the web page. That should be able to direct you to a local place.awesome Duane72. I guess the only thing I would like to find out if there is someone local in my area I could buy some of this stuff just in case, I want it ASAP.
is there a specific battery tender I require? and is this just recommended for PWC Batteries or can it be used on boat batteries?
So what are these actually called? Battery maintenance? And is there a brand I should buy?
great thanks. So if i went to walmart, what would best suit my needs and what would it be called? Float charger? and brand name? Sorry for all the questions.
back tracking a bit, post #6, with regards to Fogging, where is the intake duct located exactly?
duane72, so the duct is the small opening just below the small storage locker, when you say storage locker, i assume the little compartment you would store your keys and small things. and this duct has a small amount of suction? so just run unit for a few minutes and spray in the duct, and this will cover everywhere? why not just spray all around the motor, since the seats are off when you do this anyways? I did pick up fogging oil, as well i bought some Seafoam, I noticed the Seafoam was on a old receipt from the previous owners receipts maintenance. Is Seafoam any good for a 4tec. It says it is good for the plugs and fuel. I read briefly and it sounds like mixed reviews. I have fuel Stabilizer as well as i got a package deal fogging oil and fuel stabilizer together, just in case I shouldn't use the Seafoam.
Duane72, thanks once again. One last thing that I am not clear on for winterizing is flushing the system with antifreeze. I know where the flush port is to flush and how to connect a hose to it, however how do you add antifreeze and run it throw the system? I have read some use a bilge pump to pump it throw the port. Is there another way if I don't have a pump, can I just poor the antifreeze in to one area rather than flushing throw the port? Also do I use 100% antifreeze?
