Parting out a 1995 XP
1969iggy
Motor is out... had low compression. I took it apart so i can post pics if interested.
Front e-box with mpem and wire harness is available. It's missing the VTS unit from it. VTS was non-functioning on this one.
Most of the other parts are available.
Drive shaft
pump (wear ring is shit, but spins freely)
seats/hood
hood wiring harness
exhaust (was repaired with JB weld by previous owner in the one aluminum plug)
Waterbox
choke wire
Steering
polystyrene handlebar cover (Actual cover was garbage, but if you want the foam to go underneath...)
Gas selector/gas tank/oil tank
Fuel baffle (not sure if it worked for the gauge, but can try to test if you are interested).
If you ask, i'll check...
was a 720. The e-box had everything but the VTS control in it. My VTS didn't work and maybe they took it out to simplify the electronics, sold it... not sure. But the motor started and ran until it sh!t the bed... so MPEM and the rest should be good. Make a fair offer, my wife wants stuff out of the garage and i'm selling the hull... the engine might be a science project for one of the kids....
