parting out 97 spx and 97 Sp
marlboroa
Parting out a complete 97 sp unless someone wants to buy it complete really fast. I have a clear title for it.
parts that i have left from the 97 SPX are
throttle lever with cable
Steering Cable
Choke cable
Front tow hook
Ride plate
gas tank can i even ship this???
fuel Pump/baffle whatever it is
Storage bucket
water box
rubber exaust hose
now parts that are on the 97 sp are all stock except for the stuff that i took from the SPX to put on it. they are
Pump/Impeller
Yellow Hood with Fuel gauge and vts gauge, I think the fuel gauge has a crack in the glass
Black side fins, rub rails, and sponsons, fuel selector, oil and gas caps and the two back floor mats in black
The rest of the ski is all stock sp. The motor will need a new top end. it had 120 compression in both but when i took the head off i seen that they where pitted and one cylender needs to be honed. there is also 2 bolts broken off in the same jugg. other than that everything else is in good shape.
Im open to offers on this stuff, im just trying to get some of my money back on it.
pics of this stuff are on my photobucket. if you need anymore just ask me.
http://smg.photobucket.com/albums/v472/marlboroa/97%20seadoo%20sp/
Hi marlboroa,
Do you know if the pump/impellar from your spx which you put on your 97 sp will work on my 95 sp? My cone got cracked somehow and all the oil ran out and of course the bearings got destroyed. If it will work, how much do you want for it?
Thanks,
Larry
as far as i know it should bolt up to it, i dont know how it will act performance wise cause the spx has a different pitch then the sp. Maybe one of the more experienced guys can chime in on this. Ill be posting pics of all this later today. I just got it all taken apart yesterday.
parts with pics. im selling this all just make me an offer. click the pics to make them bigger. on stuff like the hood and motor. i can sell parts or complete
SP seat
gas tanks
Sp oil tank
Spx pump
717 motor forgot to add that this motor does not run. needs a top end job forsure and i dont know what else. It does spin but hangs up in one spot.
sp handlebars
sp driveshaft
sp pipes
sp waterbox
spx rideplate
spx bucket
sp motor mounts
sp choke cable
sp mpem with key and post
sp airbox
spx sponsoons and steering cable
spx rear coil box
spx selector gas and oil caps
spx motor mounts
spx hood and front hook handlebar foam
I might need the sponsons, one of mine is cracked, but right now that's probably all I need. I already got a pump.
Thanks for your input.
Im in Wichita Falls, its about 2 hours north of fort worth. Right now the motor still has everything on it. so just make an offer on it and what all you want on it. I.E. carb, starter exhaust, and so on
