Part numbers
Deadlygunz
Hello
I have a seadoo challanger 2003 with the merc 240 Oe376466
And i an looking for part but i dont know if the part numbers are correct
I found :
Impeller #47-877326T
Ride plate 856627t3
Inlet grate kit 856627t3
I have to order the part from us to europe so have to be sure if they are correct i hope someone can help me
Hello
I found :
Ride plate 856627t3
The is the source I use.
bammarine.com
Genuine Mercury & Mercruiser parts. 240 EFI M2 JET DRIVE (PUMP) - 0E370718 THRU 0E379930 for your engine.
Regarding your intake grate- There have been many cases of tines and spring fingers breaking and damaging impeller and wear ring. I suggest the aluminum cast grate. Instead of "tines", they are secure at both ends.
Mercury-Mercruiser 852962T SCREEN.
Expensive. Occasionally on ebay.
Ride plate. Not sure what can go wrong with the ride plate.
Impeller. Any shop that works on jet ski impellers, should be able to work on yours. Very expensive.
What is the condition of your wear ring?
