P1106 code help.
Jasonrees
Hi all.
Anyone know what p1106 code is on 2010 rxt260rs.
Ski fires and stops instantly throwing above code.
Ran great last week and it's been sat in the garage since.
Hi all.
Reporting Module ECM
Altitude correction factor not plausible - out of range
There is no Possible Cause or Service Action listed.
update - seems solved - took the map sensor off - looked clean. took the main relay out of the fuse box. some of the prongs had a bit of residue - sandy them all tweeked them a bit and reinstalled - 2 hours - perfect.
No more codes - no more random shut off.
The above was copied off another forum, a 2016 was throwing the 1106 code and this was the solution
Quick update .....All fixed!!!
Turned out my riva athena ecu took a dump and took my MAP sensor out with it.
New sensor fitted along with standard ecu today and fired straight up perfectly.
Riva athena starts but no throttle...dead :(.
Map tuner x it is then.
Thanks for your help.
