P0107
Jonsah
I have 2009 sea doo gtx 255 iS that shows code P0107. I checked the map sensor and it seems to be fine. The connector has 5 volts going to it and I cannot seem to find the issue. Also the sea doo does not rev up. Shifts to foward but won’t take any throttle after that. Idles very rough. Any help?
How did you check the map sensor? Did you use a BUDS tool or a Candoo Pro? Did you physically remove it and make sure it wasn't dirty or the port blocked?
