overheating!!!!
chris2346
I finally got the fuel problem fixed on my 96 sea doo speedster 170. it runs great, thanks for everyones imput, it helped alot... got it out on the lake last weekend and my beeper thing went off and would not shut up!! it was quite irritating. i shut the motors down and realized one was hot. i took the wire off of the temp sensor on the head and started the motor back up and their was no beeping, as soon as i put the wire back on the beeping came back. i also noticed their was not a stream of water pissing out of the little hole by the tow hook on the back of the boat. the other motor seems to be fine and it has a stream pissing out of the other little hole when it is running. does anyone have any idea's? thanks alot...
Sounds like you have a cooling obstruction, in the motor not peeing...
I would flush the motor on the hose and see if you can blow the trash out of the cooling system that way....
thanks i'll give it a try when i get out of work today.. does anyone know if their is a filter or screen of somesort where the water intake is.
