One more hose..2001 GTX DI
seadoodoopartsofcf
Ski was in a box when I received it...had wrong cylinder head, one cylinder bored out 7 thousands too much ( low compression ) crank bolt stripped, etc..real basket case..all I have left to find out at this point is where this hose goes..it's the big one off the air compressor..the hose leads to the bottom of the hull by the stator..don't know if there's a missing " t " and it plugs into the bottom of the exhaust..any help would be appreciated
Look at hose #76
Find the air pump on the right side of the explosion drawing. Look at the hose that is "grayed out" then look to the left of the engine. You'll see the hose in it's full length and where it goes to.
convert
Thanks everyone for the help, update..I put it all back together and it's got bad crank bearings...lol ..at least I know where everything goes...back out it comes!
