oil
shaft
If the motor is not getting any injection oil how long will it run and what kind of damage will occur. Thanks Shaft
Yeah if there is no oil, damage WILL occur, just a matter of when. It wont take long though. If the injection system isnt working properly, you need to premix till you get it figured out.
It does the same thing as running your car with no oil. It'll lock it up. If your lucky, you would only need a new top end. If you're not lucky, you'd need a whole new engine.
Yep. That is how 2 stroke engines work. They dont have a crankcase filled with oil. They rely on it being mixed in with the gas.
