Boat has been running great. Ran up the river normally today, ran mostly around 6000 RPM, opened it up all the way a couple of times, all perfectly normal
Stopped for a little bit, then restarted, and at about 3500 RPM, oil warning came on with a long beep. I shut it down immediately, checked the oil, which was about 1/4 inch above the high mark, so definitely not low. I am not sure how much the level read high because it was hot.
Restarted and ran at idle for a while then slowed bumped it up about 200 RPM every couple minutes. At about 3500 got the oil warning again. Ran fine up to that point.
Brought it back in at 2500 RPM no problem.
Thoughts? Oil pressure sensor?
