oil pump
hawkeye50654
I have 2 '99 spx jet skis i bought from my nebighor and after i purchased one started smoking badly, i got him to work on them since im new to pwc he said he replaced the spring on the oil pump and patched a hole in the exhaust, now the other one is having the same symptoms and using more oil than the other, they usually use about the same amount, my nebighor is now away in the service for a few months and i was wondering what kind of a job it is to fix this or could there be a different problem
Thx
disconnect the oil pump blind all ends, and mix the oil into the gas before u poor it to your pwc... then you will have the safest oil-to-gas mix...
and no need to worry of the pump anymore....
i have blown 2-stroke motors by releying on the oil pump mixing correct amount og oil to the gasoline....
