Oil pump on my 1997 seadoo spx is stuck
Leeboy163
So I cleaned my carb and when I put it back when ever I press the throttle it goes up but don’t come down unless I push it
Make sure you have the oil pump arm spring wound the correct way. It is possible to have it wound the wrong way putting no return tension on the arm.
This happened to me yesterday. I took the two allen screws out of the pump, removed it and re-seated the spring in the correct place (there is a small notch that it will hook to). You might have to mess with it for a bit to get it seated.
