Oil pressure sensor question?? PLEASE HELP!
79chriscraft33
OK, I have a 2001 gs. The oil tank was leaking at the seams. So I purchased a new tank, all new seals, and filter. When I pulled the pressure sensor out, I noticed that the little pill bottle looking thing at the lowest part of the sensor had a loose cap???(see pic, allen wrench at seam)
Not sure if that should be sealed.?.?
Just dont want to put it tegether if I need to replace the sensor first.
Any help would be much appreciated.
Thanks for your help!!:cheers:
Marc
Off the top of my head, I can't remember if that was normal or not. BUT... I would say it's OK, since the seadoo sensor let's the oil inside.
Was the sensor working before it was removed?
Thanks
Thanks for the reply. I just purchased this seadoo. I was told it was in "great" condition. So im not sure if the sensor works or not. Im going to put it back together and give it a shot.
Thanks again!
Marc
The seadoo sensor takes a while to saturate with oil... so if it's been out of the oil for a while... it could take a day or so before the oil light will go out.
